Einleitung
Having suspicion that your handset is not charging well due to bad contact? You've come to the right guide!
Was du brauchst
Turn the base over. You will see four 11mm Phillips #0 screws, one in each corner.
Use a screwdriver to remove all four 11mm Phillips #0 screws.
Locate an easy seam for entry and insert the metal spudger to separate the plastic. Use the spudger in multiple places if necessary.
Locate the charging component towards the bottom of the grey, plastic, phone-shaped extrusion. It is composed of two metal pieces; each is fastened by a 5mm Phillips #0 screw.
Remove both 5mm Phillips #0 screws to release the metal pieces.
Cut the black and red wires to finish removal, and then solder your new replacement component.
For more help on soldering, please refer to the iFixit Solder and Desolder Guide.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
