Einleitung
This is a guide to replace the battery of the Chromo Noria. Replacing the battery is one of the main important replacements. Without a functional battery, the life of the tablet ceases to exist.
Was du brauchst
Insert your Plastic Opening Tool into the crease between the front panel and back panel.
Slide the Opening Tool around the entire device. As you progress, you should see the device open.
Carefully turn the device over.
Lay the back panel aside so you can see the device's parts.
Place your finger at the end of the tape closest to the battery.
Peel the tape towards the flex cables to free the battery wires.
Using the spudger tool, place the tool along an edge of the battery.
Move the spudger around the edges of the battery to detach it from the tablet.
Using a soldering iron, desolder both of the battery wires. The battery's wires are located to the left of the camera's flex cable.
Remove the battery.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
