Einleitung
The purpose of this guide is to communicate steps on how to replace or repair the controller ports on a ColecoVision.
Was du brauchst
Flip the ColecoVision over with the pegs facing the ceiling.
Remove the eight 15mm screws holding the bottom of the ColecoVision in place using the Phillips #1 screwdriver.
Carefully remove the bottom of the ColecoVision out of the top.
I would recommend running a metal spudger along the rim of the case to remove the bottom.
Remove the two 15mm screws holding the casing in place using the Phillips #1 screwdriver.
Remove the casing and put it to the side.
Remove the two 15mm screws on the motherboard with a Phillips #1 screwdriver.
Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
Flip the motherboard over and locate the two controller ports.
Using a soldering iron, desolder the controller ports.
After waiting for controller ports to cool down, flip motherboard back over and carefully lift controller ports to remove.
