Zum Hauptinhalt wechseln
ColecoVision Controller Port Replacement
Was du brauchst
  1. ColecoVision Controller Port Replacement, Controller Port: Schritt 1, Bild 1 von 1
    • Flip the ColecoVision over with the pegs facing the ceiling.
    • Remove the eight 15mm screws holding the bottom of the ColecoVision in place using the Phillips #1 screwdriver.
  2. ColecoVision Controller Port Replacement: Schritt 2, Bild 1 von 2 ColecoVision Controller Port Replacement: Schritt 2, Bild 2 von 2
    • Carefully remove the bottom of the ColecoVision out of the top.
    • I would recommend running a metal spudger along the rim of the case to remove the bottom.
  3. ColecoVision Controller Port Replacement: Schritt 3, Bild 1 von 2 ColecoVision Controller Port Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 15mm screws holding the casing in place using the Phillips #1 screwdriver.
    • Remove the casing and put it to the side.
  4. ColecoVision Controller Port Replacement: Schritt 4, Bild 1 von 2 ColecoVision Controller Port Replacement: Schritt 4, Bild 2 von 2
    • Remove the two 15mm screws on the motherboard with a Phillips #1 screwdriver.
    • Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
  5. ColecoVision Controller Port Replacement: Schritt 5, Bild 1 von 3 ColecoVision Controller Port Replacement: Schritt 5, Bild 2 von 3 ColecoVision Controller Port Replacement: Schritt 5, Bild 3 von 3
    • Flip the motherboard over and locate the two controller ports.
    • Using a soldering iron, desolder the controller ports.
    • Refer to this soldering technique guide for reference.
    • After waiting for controller ports to cool down, flip motherboard back over and carefully lift controller ports to remove.
Abschluss
Bobby
380 Reputation
2 Anleitungen geschrieben
UW Tacoma, Team S1-G2, Rose Fall 2018 Mitglied von UW Tacoma, Team S1-G2, Rose Fall 2018
UWT-ROSE-F18S1G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 1,111
