Zum Hauptinhalt wechseln
Comfort Zone CZ6C Switch Replacement
Was du brauchst
  1. Comfort Zone CZ6C Switch Replacement, Switch: Schritt 1, Bild 1 von 3 Comfort Zone CZ6C Switch Replacement, Switch: Schritt 1, Bild 2 von 3 Comfort Zone CZ6C Switch Replacement, Switch: Schritt 1, Bild 3 von 3
    • Make sure to unplug the Comfort Zone CZ6C before cutting any wires.
    • Before replacing your switch, learn how to solder using the How To Solder and Desolder Connections Guide.
    • Start with the fan on its back. Unscrew the back panel to expose the internal wiring.
  2. Comfort Zone CZ6C Switch Replacement: Schritt 2, Bild 1 von 2 Comfort Zone CZ6C Switch Replacement: Schritt 2, Bild 2 von 2
    • Remove the plastic cover on the switch by pulling it apart from the the back panel.
  3. Comfort Zone CZ6C Switch Replacement: Schritt 3, Bild 1 von 1
    • Use the soldering iron with caution. Don't touch the tip of the soldering iron to avoid the risk of injury.
    • This step can be made easier with the help of a partner to hold the wiring while you desolder the connection.
    • Disconnect the gray power wire from the switch by desoldering the connection.
  4. Comfort Zone CZ6C Switch Replacement: Schritt 4, Bild 1 von 2 Comfort Zone CZ6C Switch Replacement: Schritt 4, Bild 2 von 2
    • Cut the green and yellow wire as close to the switch connection as possible.
  5. Comfort Zone CZ6C Switch Replacement: Schritt 5, Bild 1 von 3 Comfort Zone CZ6C Switch Replacement: Schritt 5, Bild 2 von 3 Comfort Zone CZ6C Switch Replacement: Schritt 5, Bild 3 von 3
    • Strip the green and yellow wire about two centimeters from where it was just cut.
  6. Comfort Zone CZ6C Switch Replacement: Schritt 6, Bild 1 von 3 Comfort Zone CZ6C Switch Replacement: Schritt 6, Bild 2 von 3 Comfort Zone CZ6C Switch Replacement: Schritt 6, Bild 3 von 3
    • Unscrew the switch from the back panel and remove it.
  7. Comfort Zone CZ6C Switch Replacement: Schritt 7, Bild 1 von 3 Comfort Zone CZ6C Switch Replacement: Schritt 7, Bild 2 von 3 Comfort Zone CZ6C Switch Replacement: Schritt 7, Bild 3 von 3
    • After replacing the switch, resolder the gray power cord, the green wire, and the yellow wire.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 17-5, Forte Spring 2015 Mitglied von Cal Poly, Team 17-5, Forte Spring 2015
CPSU-FORTE-S15S17G5
4 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
I need a replacement switch for a Comfort Zone CZ40 heater. Can you help?
Michael Drasic - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 2,288
