Zum Hauptinhalt wechseln
Conair Cord-Keeper 169XR On/Off Switch Replacement
Was du brauchst
  1. Conair Cord-Keeper 169XR On/Off Switch Replacement, Handle Cover: Schritt 1, Bild 1 von 2 Conair Cord-Keeper 169XR On/Off Switch Replacement, Handle Cover: Schritt 1, Bild 2 von 2
    • Unscrew the two 18 mm long Phillips #2 screws on the side of the hair dryer.
  2. Conair Cord-Keeper 169XR On/Off Switch Replacement: Schritt 2, Bild 1 von 1
    • Be cautious of pieces that can possibly fall out when removing the face of the handle.
    • Once you have taken the screws out, take the top half of the handle off by lifting it off of the dryer.
  3. Conair Cord-Keeper 169XR On/Off Switch Replacement, On/Off Switch: Schritt 3, Bild 1 von 2 Conair Cord-Keeper 169XR On/Off Switch Replacement, On/Off Switch: Schritt 3, Bild 2 von 2
    • Now take out the On/Off switch by gently pulling it out towards you and lightly pushing it to the right with your finger until it comes out of the groove it is resting in.
    • Once the new switch is in place you can put the dryer back together.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Candace
992 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 10-33, Maness Winter 2014 Mitglied von Cal Poly, Team 10-33, Maness Winter 2014
CPSU-MANESS-W14S10G33
3 Mitglieder
3 Kommentare
Looks to me that a replacement switch would be required. How can obtain one?
Jaky Felix - Antwort
“No parts required” is what’s displayed by default when there’s no link to an actual part for sale—it’’s a bit silly and clearly incorrect in this case. For hard-to-find parts, check eBay or Amazon. Also, a lot of folks with multiple broken units use these guides to cobble together one working unit from the parts. Good luck!
Jeff Suovanen -
That was my question, where can I get a replacement switch?
Constance Hudson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 29
Insgesamt: 3,041
