Einleitung
If your hair dryer's fan grill is damaged or dirty, this guide will show you how to replace it.
Was du brauchst
Starting from where the cord attaches to the handle, pull apart the two plastic panels.
Continue separating the back panel, working along the seam.
With moderate force, completely remove the back panel from the hair dryer.
Hold the hair dryer by the nozzle so that the handle points to the left.
Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
Lift the attached electrical wiring and heat shield completely out of the hair dryer.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
