Zum Hauptinhalt wechseln
Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement
Was du brauchst
    1. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement, Back Panel: Schritt 1, Bild 1 von 1
      • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
      • Hold the hair dryer by the handle so that the back panel faces up.
      Frag FixBot
      Kommentar hinzufügen
    2. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: Schritt 2, Bild 1 von 2 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: Schritt 2, Bild 2 von 2
      • Remove the two 15.875 mm Phillips #2 screws from the back panel.
      Frag FixBot
    3. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: Schritt 3, Bild 1 von 3 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: Schritt 3, Bild 2 von 3 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: Schritt 3, Bild 3 von 3
      • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
      • Continue separating the back panel, working along the seam.
      • With moderate force, completely remove the back panel from the hair dryer.
      Frag FixBot
    1. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement, Fan Motor Assembly: Schritt 4, Bild 1 von 2 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement, Fan Motor Assembly: Schritt 4, Bild 2 von 2
      • Hold the hair dryer by the nozzle so that the handle points to the left.
      • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
      Frag FixBot
    2. Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: Schritt 5, Bild 1 von 3 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: Schritt 5, Bild 2 von 3 Conair Infiniti Pro Model 259NP Fan Motor Assembly Replacement: Schritt 5, Bild 3 von 3
      • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
      • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
      • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
      Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 10-58, Amido Spring 2014 Mitglied von Cal Poly, Team 10-58, Amido Spring 2014
CPSU-AMIDO-S14S10G58
4 Mitglieder
42 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 49
Insgesamt: 8,601
