Einleitung
Replacing the RGB lights in the earcups is a technical process that includes disassembly and soldering. This guide walks you through each of the steps to replace the lights in the righthand earcup. For this guide, you will need a soldering kit and a screw driver kit.
Was du brauchst
Carefully remove earmuff from headphones by getting a grip under the earmuff cushion and peeling up over the lip that keeps it in place.
Using the Phillips #0 screwdriver, unscrew the seven 6.4 mm screws holding the black speaker cover in place.
Using the Phillips #0 screwdriver, remove the three 6.4 mm screws on the black plastic panel with the grid of holes.
There is a small circuit board near the bottom of the muff.
Using a Phillips #0 screwdriver, unscrew the single screw holding the circuit board in place.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Remove the circuit board from its plastic slot.
Desolder the three points where the wires connect to the circuit board. For detailed instructions on soldering, see this helpful guide.
Follow these steps again to replace the light on the other earcup.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
