Einleitung
Replacing the speakers is a difficult task. It will required you to disassemble both sides of the headphones and require soldering skills. You will need to have a soldering kit to do this replacement. Replacing the speakers can be difficult without prior mechanical experience, so make sure you give yourself the necessary time to complete this replacement.
Was du brauchst
Carefully remove earmuff from headphones by getting a grip under the earmuff cushion and peeling up over the lip that keeps it in place.
Using the Phillips #0 screwdriver, unscrew the seven 6.4 mm screws holding the black speaker cover in place.
4 weitere Personen haben diese Anleitung absolviert.
5 Kommentare
Where can i find a new speaker ?
