Zum Hauptinhalt wechseln
Creative Nomad Jukebox Zen Auxiliary Jack Input placement
Was du brauchst
  1. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: Schritt 1, Bild 1 von 3 Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: Schritt 1, Bild 2 von 3 Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Front and Back Cover: Schritt 1, Bild 3 von 3
    • Use a J0 screwdriver to remove the eight 3.5mm screws.
  2. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: Schritt 2, Bild 1 von 3 Creative Nomad Jukebox Zen Auxiliary Jack Input placement: Schritt 2, Bild 2 von 3 Creative Nomad Jukebox Zen Auxiliary Jack Input placement: Schritt 2, Bild 3 von 3
    • Use the plastic opening tool to open the top cover by carefully prying at each corner.
  3. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Screen Cover: Schritt 3, Bild 1 von 1
    • Once the front face is removed, remove the three 6.8mm J0 screws from the metal cover and remove it.
  4. Creative Nomad Jukebox Zen Auxiliary Jack Input placement, Auxiliary Port: Schritt 4, Bild 1 von 1
  5. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: Schritt 5, Bild 1 von 1
    • Using the plastic opening tool, gently pry up the other side of the auxiliary jack motherboard.
  6. Creative Nomad Jukebox Zen Auxiliary Jack Input placement: Schritt 6, Bild 1 von 1
    • Using the plastic pulling tool, pull the plastic housing of the device out of the way in order to wiggle the the auxiliary jack motherboard free.
Abschluss
Bradley McHugh
101 Reputation
1 Anleitung geschrieben
IUPUI, Team S4-G5, Baechle Spring 2017 Mitglied von IUPUI, Team S4-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 582
