Zum Hauptinhalt wechseln
Creative Zen V Plus Headphone Jack Replacement
Was du brauchst
  1. Creative Zen V Plus Headphone Jack Replacement, Prerequisite Only: Schritt 1, Bild 1 von 1
    • Find the grooves around the buttons on the front and carefully remove the panel. This can be done without the use of any tools.
  2. Creative Zen V Plus Headphone Jack Replacement: Schritt 2, Bild 1 von 1
    • Using a plastic opening tool, place the skinny flat end between the groove running along side of the device.
    • Using a twisting motion, detach the control panel from the device
  3. Creative Zen V Plus Headphone Jack Replacement: Schritt 3, Bild 1 von 1
    • Find the groove around the outside of the green section. Use an ESD safe spudger to slowly lift the plastic panel up.
  4. Creative Zen V Plus Headphone Jack Replacement: Schritt 4, Bild 1 von 2 Creative Zen V Plus Headphone Jack Replacement: Schritt 4, Bild 2 von 2
    • After removing the green section, find the groove around the display. Insert a ESD safe spudger and carefully lift the display.
  5. Creative Zen V Plus Headphone Jack Replacement: Schritt 5, Bild 1 von 1
    • The display can lift up the display but be sure not to damage any of the cables connecting it to the mother board.
    • Remove the screw located under the display using the 00 Phillips head screwdriver.
  6. Creative Zen V Plus Headphone Jack Replacement: Schritt 6, Bild 1 von 3 Creative Zen V Plus Headphone Jack Replacement: Schritt 6, Bild 2 von 3 Creative Zen V Plus Headphone Jack Replacement: Schritt 6, Bild 3 von 3
    • Pull up on the motherboard and display. It is glued to the base so it will require a little force. Be careful though, as the board is fragile.
  7. Creative Zen V Plus Headphone Jack Replacement, Headphone Jack: Schritt 7, Bild 1 von 1
    • Locate the circles of metal holding the headphone jack to the logic board. Using a soldering iron, de-solder these circles and remove the headphone jack.
Abschluss
Joshua Meines
316 Reputation
3 Anleitungen geschrieben
IUPUI, Team 2-5, Baechle Fall 2016 Mitglied von IUPUI, Team 2-5, Baechle Fall 2016
IUPUI-BAECHLE-F16S2G5
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 335
