Zum Hauptinhalt wechseln
CrystalView NB4-35788 Auxiliary Speakers Replacement
Was du brauchst
  1. CrystalView NB4-35788 Auxiliary Speakers Replacement, Auxiliary Speakers: Schritt 1, Bild 1 von 1
    • Power off the device before beginning disassembly.
    • Using a Phillips #00 Screwdriver, take out the following screws:
    • Two 6 mm screws
    • Three 4 mm screws
    • Four 3 mm screws
    • These screws can be taken out in any order.
  2. CrystalView NB4-35788 Auxiliary Speakers Replacement: Schritt 2, Bild 1 von 1
    • Using a Phillips #00 Screwdriver, remove the screws located under the top two standoffs.
  3. CrystalView NB4-35788 Auxiliary Speakers Replacement: Schritt 3, Bild 1 von 1
    • Remove the cover off the back of the device.
  4. CrystalView NB4-35788 Auxiliary Speakers Replacement: Schritt 4, Bild 1 von 1
    • Two speakers can be found on the device, one in the lower-right corner and one in the lower left-corner.
  5. CrystalView NB4-35788 Auxiliary Speakers Replacement: Schritt 5, Bild 1 von 1
    • Gently pull up on the speaker to remove it. Repeat this for the other speaker.
  6. CrystalView NB4-35788 Auxiliary Speakers Replacement: Schritt 6, Bild 1 von 2 CrystalView NB4-35788 Auxiliary Speakers Replacement: Schritt 6, Bild 2 von 2
    • De-solder the red and black wires to disconnect the old speaker.
    • Be careful while using a soldering iron as it is extremely hot.
    • Follow the How To Solder and Desolder Connections guide for help.
Abschluss
Alex Stokes
101 Reputation
1 Anleitung geschrieben
Oakland University, Team 2-6, Ruskiewicz Winter 2017 Mitglied von Oakland University, Team 2-6, Ruskiewicz Winter 2017
OAK-RUSKIEWICZ-W17S2G6
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 141
