Zum Hauptinhalt wechseln
CrystalView NB4-35788 Battery Replacement
Was du brauchst
  1. CrystalView NB4-35788 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power off the device before beginning disassembly.
    • Using a Phillips #00 Screwdriver, take out the following screws:
    • Two 6 mm screws
    • Three 4 mm screws
    • Four 3 mm screws
    • These screws can be taken out in any order.
  2. CrystalView NB4-35788 Battery Replacement: Schritt 2, Bild 1 von 1
    • Using a Phillips #00 Screwdriver, remove the screws located under the top two standoffs.
  3. CrystalView NB4-35788 Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the cover off the back of the device.
  4. CrystalView NB4-35788 Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the battery using a plastic spudger.
    • Do not use a metal spudger, as this can damage the device.
  5. CrystalView NB4-35788 Battery Replacement: Schritt 5, Bild 1 von 2 CrystalView NB4-35788 Battery Replacement: Schritt 5, Bild 2 von 2
    • Peel back the yellow film on the old battery to expose the red and black wires
    • De-solder these wires to disconnect the old battery
    • Be careful while using a soldering iron as it is extremely hot.
    • Follow the How To Solder and Desolder Connections guide for help.
Abschluss
Courtney Clark
218 Reputation
2 Anleitungen geschrieben
Oakland University, Team 2-6, Ruskiewicz Winter 2017 Mitglied von Oakland University, Team 2-6, Ruskiewicz Winter 2017
OAK-RUSKIEWICZ-W17S2G6
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 300
