Einleitung
Replace your dying battery to restore the power of your CrystalView Netbook.
Was du brauchst
Using a Phillips #00 Screwdriver, take out the following screws:
Two 6 mm screws
Three 4 mm screws
Four 3 mm screws
Using a Phillips #00 Screwdriver, remove the screws located under the top two standoffs.
Peel back the yellow film on the old battery to expose the red and black wires
De-solder these wires to disconnect the old battery
Follow the How To Solder and Desolder Connections guide for help.
