Zum Hauptinhalt wechseln
Cuisinart DFP-14BCN Switch Replacement
Was du brauchst
  1. Cuisinart DFP-14BCN Switch Replacement, Bowl: Schritt 1, Bild 1 von 3 Cuisinart DFP-14BCN Switch Replacement, Bowl: Schritt 1, Bild 2 von 3 Cuisinart DFP-14BCN Switch Replacement, Bowl: Schritt 1, Bild 3 von 3
    • Unplug your food processor before starting any disassembly.
    • Remove the small pusher by rotating it clockwise and lifting up.
  2. Cuisinart DFP-14BCN Switch Replacement: Schritt 2, Bild 1 von 1
    • Remove the large pusher by grabbing its sides and pulling up.
    • There may be a clicking sound from the safety feature being disengaged in this step.
  3. Cuisinart DFP-14BCN Switch Replacement: Schritt 3, Bild 1 von 3 Cuisinart DFP-14BCN Switch Replacement: Schritt 3, Bild 2 von 3 Cuisinart DFP-14BCN Switch Replacement: Schritt 3, Bild 3 von 3
    • Remove the lid from the bowl by turning it clockwise and lifting.
  4. Cuisinart DFP-14BCN Switch Replacement: Schritt 4, Bild 1 von 1
    • Take out the blades by grabbing the plastic center piece and lifting up.
    • Avoid contact with blades as they are extremely sharp.
  5. Cuisinart DFP-14BCN Switch Replacement: Schritt 5, Bild 1 von 3 Cuisinart DFP-14BCN Switch Replacement: Schritt 5, Bild 2 von 3 Cuisinart DFP-14BCN Switch Replacement: Schritt 5, Bild 3 von 3
    • Position the handle of the bowl so that it is on your left.
    • Grab the handle and push clockwise. Lift up the bowl to remove it.
  6. Cuisinart DFP-14BCN Switch Replacement, Back Casing: Schritt 6, Bild 1 von 2 Cuisinart DFP-14BCN Switch Replacement, Back Casing: Schritt 6, Bild 2 von 2
    • Turn the food processor's base upside down by lifting it up and turning it over.
    • Position the base so that the on and pulse buttons are facing you.
    • Place the base on top of the food processor's bowl to keep the base from wobbling while you work on it.
  7. Cuisinart DFP-14BCN Switch Replacement: Schritt 7, Bild 1 von 2 Cuisinart DFP-14BCN Switch Replacement: Schritt 7, Bild 2 von 2
    • Remove the two 13.0mm screws that hold down the casing with a Phillips #2 screwdriver.
  8. Cuisinart DFP-14BCN Switch Replacement: Schritt 8, Bild 1 von 3 Cuisinart DFP-14BCN Switch Replacement: Schritt 8, Bild 2 von 3 Cuisinart DFP-14BCN Switch Replacement: Schritt 8, Bild 3 von 3
    • Lift up the front left and the back right rubber feet by pulling back the rubber with your fingers.
    • Remove the 13.0mm screw under each rubber foot with a Phillips #2 screwdriver.
  9. Cuisinart DFP-14BCN Switch Replacement: Schritt 9, Bild 1 von 2 Cuisinart DFP-14BCN Switch Replacement: Schritt 9, Bild 2 von 2
    • Lift off the back casing by raising it upward.
  10. Cuisinart DFP-14BCN Switch Replacement, Buttons: Schritt 10, Bild 1 von 3 Cuisinart DFP-14BCN Switch Replacement, Buttons: Schritt 10, Bild 2 von 3 Cuisinart DFP-14BCN Switch Replacement, Buttons: Schritt 10, Bild 3 von 3
    • Remove the two 13.0mm screws that are holding down the button assembly using the Phillips #2 screwdriver.
  11. Cuisinart DFP-14BCN Switch Replacement: Schritt 11, Bild 1 von 2 Cuisinart DFP-14BCN Switch Replacement: Schritt 11, Bild 2 von 2
    • Lift out the button assembly by pulling up.
  12. Cuisinart DFP-14BCN Switch Replacement: Schritt 12, Bild 1 von 1
    • Remove the two 5.5mm nuts with a 5.5mm nut driver.
  13. Cuisinart DFP-14BCN Switch Replacement: Schritt 13, Bild 1 von 3 Cuisinart DFP-14BCN Switch Replacement: Schritt 13, Bild 2 von 3 Cuisinart DFP-14BCN Switch Replacement: Schritt 13, Bild 3 von 3
    • Remove the two 13.0mm screws that hold the switch to the button assembly with a Phillips #2 screwdriver.
    • The screws have glue in their threads, so this step might require a little extra force.
    • Slide off the switch and yellow plastic to remove the button assembly.
  14. Cuisinart DFP-14BCN Switch Replacement, Switch: Schritt 14, Bild 1 von 2 Cuisinart DFP-14BCN Switch Replacement, Switch: Schritt 14, Bild 2 von 2
    • Desolder the white, black and red connections from the switch by using a soldering iron.
    • Refer to the soldering guide for extra help.
    • For reassembly, the new switch's connections will have to be soldered on.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Sonya Dick
352 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 10-3, Livingston Fall 2016 Mitglied von Cal Poly, Team 10-3, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G3
3 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
You had me until the desoldering, maybe I’m just a wimp! Thanks anyway … good description!
dmdudek - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 38
Insgesamt: 1,619
