Zum Hauptinhalt wechseln
Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement
Was du brauchst
  1. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement, Power Cord: Schritt 1, Bild 1 von 1
    • Use a screwdriver to remove the four screws that are next to the grip pads on the bottom of the motor base.
  2. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: Schritt 2, Bild 1 von 1
    • Remove the black plastic covering from the motor base.
  3. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: Schritt 3, Bild 1 von 1
    • Locate the connections between the power cord and the brown and white wires. Cut off these connections.
  4. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: Schritt 4, Bild 1 von 1
    • Strip the plastic coating off the edge of the brown and white wires using a wire stripper.
  5. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: Schritt 5, Bild 1 von 1
    • Create a connection between the brown and white wires and the wires of the new power cord by soldering them together.
  6. Cuisinart DLC-10S Pro Classic 7-Cup Food Processor Power Cord Replacement: Schritt 6, Bild 1 von 1
    • Fit the wires back into the motor base and place the new power cord in the slot.
Abschluss
By the end of this guide< you will have successfully replaced the power cord to your device.
Eine weitere Person hat diese Anleitung absolviert.
Reagan Burns
119 Reputation
1 Anleitung geschrieben
Cal Poly, Team 24-1, Lancaster Spring 2015 Mitglied von Cal Poly, Team 24-1, Lancaster Spring 2015
CPSU-LANCASTER-S15S24G1
2 Mitglieder
4 Kommentare zur Anleitung
I can't get a replacement cord from cuisinart. Where can I buy one the same?
Elizabeth - Antwort Teilen
I need one also. drshtender1@gmail.com
Feivel Garnick - Teilen
Where can you buy the replacement cord?
ruby48lp - Antwort Teilen
There's not an exact replacement from Cuisinart, but a two prong replacement will work. I found one "Lamp Cord Set - Black - PLT 56-1854-50 | 1000Bulbs.com" https://www.1000bulbs.com/product/137344... that would work.
Riley Carns - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 24
Insgesamt: 1,988
