Zum Hauptinhalt wechseln
D-Link DIR-890L Power Adapter Port Replacement
Was du brauchst
  1. D-Link DIR-890L Power Adapter Port Replacement, Case: Schritt 1, Bild 1 von 3 D-Link DIR-890L Power Adapter Port Replacement, Case: Schritt 1, Bild 2 von 3 D-Link DIR-890L Power Adapter Port Replacement, Case: Schritt 1, Bild 3 von 3
    • Peel off the four rubber rectangular feet with your fingers.
    • The feet may be hard to remove. Apply additional force if necessary.
  2. D-Link DIR-890L Power Adapter Port Replacement: Schritt 2, Bild 1 von 3 D-Link DIR-890L Power Adapter Port Replacement: Schritt 2, Bild 2 von 3 D-Link DIR-890L Power Adapter Port Replacement: Schritt 2, Bild 3 von 3
    • Unscrew the 5mm screws in each corner using the Phillips #1 screwdriver.
  3. D-Link DIR-890L Power Adapter Port Replacement: Schritt 3, Bild 1 von 3 D-Link DIR-890L Power Adapter Port Replacement: Schritt 3, Bild 2 von 3 D-Link DIR-890L Power Adapter Port Replacement: Schritt 3, Bild 3 von 3
    • Wedge the opening tool between the red top panel and the gray bottom panel.
    • Twist the opening tool to separate the panels. Work your way around the case until both of the panels are separated.
  4. D-Link DIR-890L Power Adapter Port Replacement, Motherboard: Schritt 4, Bild 1 von 1
    • Orient the router so the narrow end of the router faces you and the ports face away from you.
    • The six, hot-glued antenna connections are in the middle and at the top right of the motherboard.
  5. D-Link DIR-890L Power Adapter Port Replacement: Schritt 5, Bild 1 von 3 D-Link DIR-890L Power Adapter Port Replacement: Schritt 5, Bild 2 von 3 D-Link DIR-890L Power Adapter Port Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Heavy-Duty Spudger
  6. D-Link DIR-890L Power Adapter Port Replacement: Schritt 6, Bild 1 von 2 D-Link DIR-890L Power Adapter Port Replacement: Schritt 6, Bild 2 von 2
    • Continue to pry off the last three antenna connections on the upper right portion of the motherboard.
  7. D-Link DIR-890L Power Adapter Port Replacement: Schritt 7, Bild 1 von 3 D-Link DIR-890L Power Adapter Port Replacement: Schritt 7, Bild 2 von 3 D-Link DIR-890L Power Adapter Port Replacement: Schritt 7, Bild 3 von 3
    • Open the plastic bracket enclosing the three antenna wires and pull the wires out with your hands.
  8. D-Link DIR-890L Power Adapter Port Replacement: Schritt 8, Bild 1 von 3 D-Link DIR-890L Power Adapter Port Replacement: Schritt 8, Bild 2 von 3 D-Link DIR-890L Power Adapter Port Replacement: Schritt 8, Bild 3 von 3
    • Pull the yellow tape off of the motherboard to release the final antenna wire.
  9. D-Link DIR-890L Power Adapter Port Replacement: Schritt 9, Bild 1 von 2 D-Link DIR-890L Power Adapter Port Replacement: Schritt 9, Bild 2 von 2
    • Pull the the motherboard away from the case to remove it. Start on the side closest to you, and pull up and out.
  10. D-Link DIR-890L Power Adapter Port Replacement, Power Adapter Port: Schritt 10, Bild 1 von 3 D-Link DIR-890L Power Adapter Port Replacement, Power Adapter Port: Schritt 10, Bild 2 von 3 D-Link DIR-890L Power Adapter Port Replacement, Power Adapter Port: Schritt 10, Bild 3 von 3
    • Locate the power adapter port at the top left of the motherboard.
    • Flip the motherboard over.
    • Locate the 3 solder joints that connect the power adapter port to the motherboard.
  11. D-Link DIR-890L Power Adapter Port Replacement: Schritt 11, Bild 1 von 3 D-Link DIR-890L Power Adapter Port Replacement: Schritt 11, Bild 2 von 3 D-Link DIR-890L Power Adapter Port Replacement: Schritt 11, Bild 3 von 3
    Desoldering Pump
    $3.99
    • Using a soldering iron and desoldering pump, desolder the power adapter port from the board.
    • For more information, see this guide on desoldering
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Rachel Shaw
553 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 10-7, Livingston Fall 2016 Mitglied von Cal Poly, Team 10-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G7
4 Mitglieder
12 Anleitungen geschrieben
1 Kommentar zur Anleitung
What are the specifications of the power port if we would like to replace it?
Chad Altobelli - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 10
Insgesamt: 788
