Zum Hauptinhalt wechseln
D-Link DIR-890L Power Switch Replacement
Was du brauchst
  1. D-Link DIR-890L Power Switch Replacement, Case: Schritt 1, Bild 1 von 3 D-Link DIR-890L Power Switch Replacement, Case: Schritt 1, Bild 2 von 3 D-Link DIR-890L Power Switch Replacement, Case: Schritt 1, Bild 3 von 3
    • Peel off the four rubber rectangular feet with your fingers.
    • The feet may be hard to remove. Apply additional force if necessary.
  2. D-Link DIR-890L Power Switch Replacement: Schritt 2, Bild 1 von 3 D-Link DIR-890L Power Switch Replacement: Schritt 2, Bild 2 von 3 D-Link DIR-890L Power Switch Replacement: Schritt 2, Bild 3 von 3
    • Unscrew the 5mm screws in each corner using the Phillips #1 screwdriver.
  3. D-Link DIR-890L Power Switch Replacement: Schritt 3, Bild 1 von 3 D-Link DIR-890L Power Switch Replacement: Schritt 3, Bild 2 von 3 D-Link DIR-890L Power Switch Replacement: Schritt 3, Bild 3 von 3
    • Wedge the opening tool between the red top panel and the gray bottom panel.
    • Twist the opening tool to separate the panels. Work your way around the case until both of the panels are separated.
  4. D-Link DIR-890L Power Switch Replacement, Motherboard: Schritt 4, Bild 1 von 1
    • Orient the router so the narrow end of the router faces you and the ports face away from you.
    • The six, hot-glued antenna connections are in the middle and at the top right of the motherboard.
  5. D-Link DIR-890L Power Switch Replacement: Schritt 5, Bild 1 von 3 D-Link DIR-890L Power Switch Replacement: Schritt 5, Bild 2 von 3 D-Link DIR-890L Power Switch Replacement: Schritt 5, Bild 3 von 3
    • Pry off the antenna connectors using a heavy-duty spudger.
  6. D-Link DIR-890L Power Switch Replacement: Schritt 6, Bild 1 von 2 D-Link DIR-890L Power Switch Replacement: Schritt 6, Bild 2 von 2
    • Continue to pry off the last three antenna connections on the upper right portion of the motherboard.
  7. D-Link DIR-890L Power Switch Replacement: Schritt 7, Bild 1 von 3 D-Link DIR-890L Power Switch Replacement: Schritt 7, Bild 2 von 3 D-Link DIR-890L Power Switch Replacement: Schritt 7, Bild 3 von 3
    • Open the plastic bracket enclosing the three antenna wires and pull the wires out with your hands.
  8. D-Link DIR-890L Power Switch Replacement: Schritt 8, Bild 1 von 3 D-Link DIR-890L Power Switch Replacement: Schritt 8, Bild 2 von 3 D-Link DIR-890L Power Switch Replacement: Schritt 8, Bild 3 von 3
    • Pull the yellow tape off of the motherboard to release the final antenna wire.
  9. D-Link DIR-890L Power Switch Replacement: Schritt 9, Bild 1 von 2 D-Link DIR-890L Power Switch Replacement: Schritt 9, Bild 2 von 2
    • Pull the the motherboard away from the case to remove it. Start on the side closest to you, and pull up and out.
  10. D-Link DIR-890L Power Switch Replacement, Power Switch: Schritt 10, Bild 1 von 3 D-Link DIR-890L Power Switch Replacement, Power Switch: Schritt 10, Bild 2 von 3 D-Link DIR-890L Power Switch Replacement, Power Switch: Schritt 10, Bild 3 von 3
    • Locate the power switch on the top left of the motherboard.
    • The power switch is the component that sticks out the furthest.
    • Turn the motherboard upside down.
    • Locate the 6 solder joints that connect the power switch to the motherboard. They are arranged in 2 columns of 3.
  11. D-Link DIR-890L Power Switch Replacement: Schritt 11, Bild 1 von 2 D-Link DIR-890L Power Switch Replacement: Schritt 11, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Desoldering Pump
    $3.99
    Kaufen
    • Using a soldering iron and desoldering pump, desolder the power switch from the board.
    • For more information, see this guide on desoldering.
Abschluss
Rachel Shaw
553 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 10-7, Livingston Fall 2016 Mitglied von Cal Poly, Team 10-7, Livingston Fall 2016
CPSU-LIVINGSTON-F16S10G7
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 1,001
