Zum Hauptinhalt wechseln
DJI Phantom 3 Standard Remote Controller Battery Replacement
Was du brauchst
  1. DJI Phantom 3 Standard Remote Controller Battery Replacement, Battery: Schritt 1, Bild 1 von 2 DJI Phantom 3 Standard Remote Controller Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Position the controller so the back is facing up and the joysticks are resting on the table.
    • Remove the four 11 mm screws that secure the back plate using a Phillips #0 screwdriver.
    • Remove the back plate, being mindful of the wires still connected to the device.
  2. DJI Phantom 3 Standard Remote Controller Battery Replacement: Schritt 2, Bild 1 von 2 DJI Phantom 3 Standard Remote Controller Battery Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 8 mm screws securing the battery to the controller using a JIS #00 screwdriver.
  3. DJI Phantom 3 Standard Remote Controller Battery Replacement: Schritt 3, Bild 1 von 3 DJI Phantom 3 Standard Remote Controller Battery Replacement: Schritt 3, Bild 2 von 3 DJI Phantom 3 Standard Remote Controller Battery Replacement: Schritt 3, Bild 3 von 3
    • Use the nylon-tipped tweezers to detach the three-prong battery attachment that connects the battery to the motherboard.
    • Remove the battery.
Abschluss
Alex Quigg
231 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 14
Letzte 30 Tage: 60
Insgesamt: 132
