Zum Hauptinhalt wechseln
DR.J Professional HI-04 Fan Replacement
Was du brauchst
  1. DR.J Professional HI-04 Fan Replacement, Fan: Schritt 1, Bild 1 von 3 DR.J Professional HI-04 Fan Replacement, Fan: Schritt 1, Bild 2 von 3 DR.J Professional HI-04 Fan Replacement, Fan: Schritt 1, Bild 3 von 3
    • Flip the projector so that the bottom is facing up.
    • Remove the eight 10.0 mm screws with a Phillips #0 screwdriver.
    • The screws are set deep in the holes. Be careful not to drop the screws.
    • Remove the two 20.0 mm screws with a Phillips #0 screwdriver.
  2. DR.J Professional HI-04 Fan Replacement: Schritt 2, Bild 1 von 3 DR.J Professional HI-04 Fan Replacement: Schritt 2, Bild 2 von 3 DR.J Professional HI-04 Fan Replacement: Schritt 2, Bild 3 von 3
    • Flip the projector so it is upright.
    • Remove the top case of the projector.
    • The top case should come off fairly easily but be gentle while removing it.
    • Don't yank the top case off as there are cables attached to the motherboard and the top case.
  3. DR.J Professional HI-04 Fan Replacement: Schritt 3, Bild 1 von 2 DR.J Professional HI-04 Fan Replacement: Schritt 3, Bild 2 von 2
    • Remove the three pieces of tape securing cables.
    • Keep the tape for reassembly.
  4. DR.J Professional HI-04 Fan Replacement: Schritt 4, Bild 1 von 2 DR.J Professional HI-04 Fan Replacement: Schritt 4, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the four 15.0 mm screws from the motherboard.
    • Be sure to not drop the screws in the device as they can be difficult to recover.
  5. DR.J Professional HI-04 Fan Replacement: Schritt 5, Bild 1 von 2 DR.J Professional HI-04 Fan Replacement: Schritt 5, Bild 2 von 2
    • Squeeze the tab against the connector, and pull the connector straight from the socket to disconnect the power cable from the port.
    • The cable should come out easily so do not pull too hard.
  6. DR.J Professional HI-04 Fan Replacement: Schritt 6, Bild 1 von 2 DR.J Professional HI-04 Fan Replacement: Schritt 6, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the three 15.0 mm screws from the black cover.
    • The screws are set deep in the holes, so be careful to not drop the screws, as they can be difficult to recover.
  7. DR.J Professional HI-04 Fan Replacement: Schritt 7, Bild 1 von 2 DR.J Professional HI-04 Fan Replacement: Schritt 7, Bild 2 von 2
    • Gently remove the black cover.
  8. DR.J Professional HI-04 Fan Replacement: Schritt 8, Bild 1 von 3 DR.J Professional HI-04 Fan Replacement: Schritt 8, Bild 2 von 3 DR.J Professional HI-04 Fan Replacement: Schritt 8, Bild 3 von 3
    • Gently remove the fan from the project.
Abschluss
Baron Dutra
825 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 1-5, Petersen Fall 2023 Mitglied von UMass Dartmouth, Team 1-5, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 29
Insgesamt: 127
