Zum Hauptinhalt wechseln
DR.J Professional HI-04 Lamp Replacement
Was du brauchst
  1. DR.J Professional HI-04 Lamp Replacement, Motherboard: Schritt 1, Bild 1 von 3 DR.J Professional HI-04 Lamp Replacement, Motherboard: Schritt 1, Bild 2 von 3 DR.J Professional HI-04 Lamp Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Flip the projector so that the bottom is facing up.
    • Remove the eight 10.0 mm screws with a Phillips #0 screwdriver.
    • The screws are set deep in the holes. Be careful not to drop the screws.
    • Remove the two 20.0 mm screws with a Phillips #0 screwdriver.
  2. DR.J Professional HI-04 Lamp Replacement: Schritt 2, Bild 1 von 3 DR.J Professional HI-04 Lamp Replacement: Schritt 2, Bild 2 von 3 DR.J Professional HI-04 Lamp Replacement: Schritt 2, Bild 3 von 3
    • Flip the projector so it is upright.
    • Remove the top case of the projector.
    • The top case should come off fairly easily but be gentle while removing it.
    • Don't yank the top case off as there are cables attached to the motherboard and the top case.
  3. DR.J Professional HI-04 Lamp Replacement: Schritt 3, Bild 1 von 2 DR.J Professional HI-04 Lamp Replacement: Schritt 3, Bild 2 von 2
    • Remove the three pieces of tape securing cables.
    • Keep the tape for reassembly.
  4. DR.J Professional HI-04 Lamp Replacement: Schritt 4, Bild 1 von 2 DR.J Professional HI-04 Lamp Replacement: Schritt 4, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the four 15.0 mm screws from the motherboard.
    • Be sure to not drop the screws in the device as they can be difficult to recover.
  5. DR.J Professional HI-04 Lamp Replacement: Schritt 5, Bild 1 von 2 DR.J Professional HI-04 Lamp Replacement: Schritt 5, Bild 2 von 2
    • Squeeze the tab against the connector, and pull the connector straight out from the socket.
    • The cable will come out easily so do not pull too hard.
  6. DR.J Professional HI-04 Lamp Replacement: Schritt 6, Bild 1 von 2 DR.J Professional HI-04 Lamp Replacement: Schritt 6, Bild 2 von 2
    • Lift the motherboard from the device.
    • Use the tip of a spudger or your fingernail to flip up the small locking flap of the ZIF connector.
    • Pull the cable from the connector.
  7. DR.J Professional HI-04 Lamp Replacement: Schritt 7, Bild 1 von 2 DR.J Professional HI-04 Lamp Replacement: Schritt 7, Bild 2 von 2
    • Set down the motherboard safely.
  8. DR.J Professional HI-04 Lamp Replacement, Lamp: Schritt 8, Bild 1 von 2 DR.J Professional HI-04 Lamp Replacement, Lamp: Schritt 8, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the three 15.0 mm screws from the black cover.
    • The screws are set deep in the holes, so be careful to not drop the screws, as they can be difficult to recover.
  9. DR.J Professional HI-04 Lamp Replacement: Schritt 9, Bild 1 von 2 DR.J Professional HI-04 Lamp Replacement: Schritt 9, Bild 2 von 2
    • Gently remove the black cover.
  10. DR.J Professional HI-04 Lamp Replacement: Schritt 10, Bild 1 von 2 DR.J Professional HI-04 Lamp Replacement: Schritt 10, Bild 2 von 2
    • Remove the single piece of black tape.
    • Save the tape for reassembly.
  11. DR.J Professional HI-04 Lamp Replacement: Schritt 11, Bild 1 von 2 DR.J Professional HI-04 Lamp Replacement: Schritt 11, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove five 10.0 mm screws.
  12. DR.J Professional HI-04 Lamp Replacement: Schritt 12, Bild 1 von 3 DR.J Professional HI-04 Lamp Replacement: Schritt 12, Bild 2 von 3 DR.J Professional HI-04 Lamp Replacement: Schritt 12, Bild 3 von 3
  13. DR.J Professional HI-04 Lamp Replacement: Schritt 13, Bild 1 von 2 DR.J Professional HI-04 Lamp Replacement: Schritt 13, Bild 2 von 2
    • Remove the glass object with the orange ribbon cable connector.
    • Be careful removing object as it is fragile and can easily break.
  14. DR.J Professional HI-04 Lamp Replacement: Schritt 14, Bild 1 von 2 DR.J Professional HI-04 Lamp Replacement: Schritt 14, Bild 2 von 2
    • Use a Phillips #0 to remove four 10.0 mm screws from the lamp.
  15. DR.J Professional HI-04 Lamp Replacement: Schritt 15, Bild 1 von 2 DR.J Professional HI-04 Lamp Replacement: Schritt 15, Bild 2 von 2
    • Gently slide the lamp out from the projector case.
Abschluss
Baron Dutra
825 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 1-5, Petersen Fall 2023 Mitglied von UMass Dartmouth, Team 1-5, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 26
Letzte 30 Tage: 79
Insgesamt: 259
