Zum Hauptinhalt wechseln
DR.J Professional HI-04 Lens Replacement
Was du brauchst
  1. DR.J Professional HI-04 Lens Replacement, Lens: Schritt 1, Bild 1 von 3 DR.J Professional HI-04 Lens Replacement, Lens: Schritt 1, Bild 2 von 3 DR.J Professional HI-04 Lens Replacement, Lens: Schritt 1, Bild 3 von 3
    • Flip the projector so that the bottom is facing up.
    • Remove eight 10.0 mm screws from the back case with a Phillips #0 screwdriver.
    • The screws are set deep in the holes, so be careful not to drop them.
    • Remove two 20.0 mm screws with a Phillips #0 screwdriver.
  2. DR.J Professional HI-04 Lens Replacement: Schritt 2, Bild 1 von 3 DR.J Professional HI-04 Lens Replacement: Schritt 2, Bild 2 von 3 DR.J Professional HI-04 Lens Replacement: Schritt 2, Bild 3 von 3
    • Flip the projector so it is upright.
    • Remove the top case of the projector.
    • The shell of the projector should lift up easily but is fragile, so be gentle while lifting.
    • The top case is connected to the motherboard by cables, so avoid yanking it off to prevent snapping the connectors or damaging components.
  3. DR.J Professional HI-04 Lens Replacement: Schritt 3, Bild 1 von 2 DR.J Professional HI-04 Lens Replacement: Schritt 3, Bild 2 von 2
    • Gently lift the black flap off from the base of the lens.
  4. DR.J Professional HI-04 Lens Replacement: Schritt 4, Bild 1 von 2 DR.J Professional HI-04 Lens Replacement: Schritt 4, Bild 2 von 2
    • Remove the lens from the projector.
    • The lens is no longer secured but might still be tightly in place. Be gentle while removing it.
  5. DR.J Professional HI-04 Lens Replacement: Schritt 5, Bild 1 von 2 DR.J Professional HI-04 Lens Replacement: Schritt 5, Bild 2 von 2
    • Unscrew the cover of the lens.
Abschluss
Kory Lajoie
127 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 1-5, Petersen Fall 2023 Mitglied von UMass Dartmouth, Team 1-5, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G5
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 15
Letzte 30 Tage: 39
Insgesamt: 234
