Zum Hauptinhalt wechseln
DROCON Ninja Propeller Replacement
  1. DROCON Ninja Propeller Replacement, Battery: Schritt 1, Bild 1 von 3 DROCON Ninja Propeller Replacement, Battery: Schritt 1, Bild 2 von 3 DROCON Ninja Propeller Replacement, Battery: Schritt 1, Bild 3 von 3
    • Make sure the drone is powered off before beginning the battery replacement.
    • To turn the drone off, press and hold the black button on the top of the drone until all lights are off.
    • Firmly grasp the battery tab between your thumb and index finger.
    • Pull the battery away from the drone's body
    Frag FixBot
  2. DROCON Ninja Propeller Replacement, Propeller: Schritt 2, Bild 1 von 2 DROCON Ninja Propeller Replacement, Propeller: Schritt 2, Bild 2 von 2
    • Firmly grasp the blade guard from the bottom of the drone
    • Pull the blade guard straight down away from motor.
    Frag FixBot
  3. DROCON Ninja Propeller Replacement: Schritt 3, Bild 1 von 3 DROCON Ninja Propeller Replacement: Schritt 3, Bild 2 von 3 DROCON Ninja Propeller Replacement: Schritt 3, Bild 3 von 3
    • Take note of the letter printed on the bottom of the propeller. Make sure the replacement propeller has the same letter.
    • Grasp the center of the propeller that needs to be replaced.
    • Pull the propeller directly up and away from the motor.
    Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
4 Kommentare zur Anleitung
can we buy an extra battery?
Orlay Gutierrez - Antwort Teilen
can we buy an extra battery for the roconDC-014
hi i have the red & bleu drocon dc-014 & wold like to order the white drocon dc-014 white drone or white body cover
tank you! & happy new year!!!
claude demers - Antwort Teilen
i both drocon dc-014 blue & red wold like by the white drocon dc-014 or uper casse
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 65
Insgesamt: 2,241
