Zum Hauptinhalt wechseln
Dell Chromebook 5190 WLAN Card Replacement
Was du brauchst
  1. Dell Chromebook 5190 WLAN Card Replacement, Battery: Schritt 1, Bild 1 von 1
    • Before starting, please make sure you have disconnected and removed all devices populating the laptop's ports.
    • Remove the nine M2.5x7.5 screws located on the bottom side of the laptop.
  2. Dell Chromebook 5190 WLAN Card Replacement: Schritt 2, Bild 1 von 3 Dell Chromebook 5190 WLAN Card Replacement: Schritt 2, Bild 2 von 3 Dell Chromebook 5190 WLAN Card Replacement: Schritt 2, Bild 3 von 3
    • Be cautious, the following instructions are to prevent cracking the base cover.
    • With the opening tool, pry open the upper left corner by the laptop hinge.
    • With the opening tool, pry open the upper right corner by the laptop hinge.
    • Lift off base cover.
  3. Dell Chromebook 5190 WLAN Card Replacement: Schritt 3, Bild 1 von 2 Dell Chromebook 5190 WLAN Card Replacement: Schritt 3, Bild 2 von 2
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top left side of the battery.
    • Unscrew and remove the M2x3 screw holding the silver metal brackets labeled "Battery Bracket" located on the top right side of the battery.
  4. Dell Chromebook 5190 WLAN Card Replacement: Schritt 4, Bild 1 von 2 Dell Chromebook 5190 WLAN Card Replacement: Schritt 4, Bild 2 von 2
    • Remove the clear adhesive tape on the system board from the battery cable from where it's seated above the battery.
    • Pull out the keyboard cable toward you to disconnect it.
  5. Dell Chromebook 5190 WLAN Card Replacement: Schritt 5, Bild 1 von 2 Dell Chromebook 5190 WLAN Card Replacement: Schritt 5, Bild 2 von 2
    • Remove the black adhesive tape on the system board from the battery cable.
    • Dismount the cable from where it's seated above the battery.
  6. Dell Chromebook 5190 WLAN Card Replacement: Schritt 6, Bild 1 von 3 Dell Chromebook 5190 WLAN Card Replacement: Schritt 6, Bild 2 von 3 Dell Chromebook 5190 WLAN Card Replacement: Schritt 6, Bild 3 von 3
    • Unscrew and remove the four M2x3 screws on each corner of the battery.
    • Dismount the battery.
  7. Dell Chromebook 5190 WLAN Card Replacement, WLAN Card: Schritt 7, Bild 1 von 2 Dell Chromebook 5190 WLAN Card Replacement, WLAN Card: Schritt 7, Bild 2 von 2
    • Unscrew and remove the M2x3 screw.
    • Remove the metal bracket.
  8. Dell Chromebook 5190 WLAN Card Replacement: Schritt 8, Bild 1 von 1
    • Remove WLAN antennas.
  9. Dell Chromebook 5190 WLAN Card Replacement: Schritt 9, Bild 1 von 1
    • Slide the WLAN card away from the motherboard.
Abschluss
Brian
97 Reputation
1 Anleitung geschrieben
Gateway, Team 1-3, Pee Spring 2022 Mitglied von Gateway, Team 1-3, Pee Spring 2022
GCC-PEE-S22S1G3
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 107
