Zum Hauptinhalt wechseln
Dell Inspiron 11 i3147 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 11 i3147 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 1
    • Close the computer and turn it over, with the bottom of the computer facing up.
  2. Dell Inspiron 11 i3147 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the nine 7.6mm PH0 screws on the cover.
  3. Dell Inspiron 11 i3147 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Use a plastic opening tool to remove the cover from the computer.
  4. Dell Inspiron 11 i3147 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Remove the three 4.7mm PH0 screws that secure the battery to the computer.
  5. Dell Inspiron 11 i3147 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Remove the hard drive cable from the battery.
  6. Dell Inspiron 11 i3147 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Lift the battery from the computer.
  7. Dell Inspiron 11 i3147 Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Peel off the adhesive strap from the hard drive.
  8. Dell Inspiron 11 i3147 Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Use a PH0 screwdriver to remove the 2 3.9 mm PH0 screws on the hard drive.
  9. Dell Inspiron 11 i3147 Hard Drive Replacement: Schritt 9, Bild 1 von 1
    • Lift the hard drive to free it from the laptop.
  10. Dell Inspiron 11 i3147 Hard Drive Replacement: Schritt 10, Bild 1 von 1
    • Remove interposer from the hard drive.
  11. Dell Inspiron 11 i3147 Hard Drive Replacement: Schritt 11, Bild 1 von 1
    • Use pull tab to remove hard drive cable from motherboard.
Abschluss
Muhammad Erchid
1.051 Reputation
5 Anleitungen geschrieben
USF Tampa, Team S1-G6, Leahy Fall 2018 Mitglied von USF Tampa, Team S1-G6, Leahy Fall 2018
USFT-LEAHY-F18S1G6
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 246
