Zum Hauptinhalt wechseln
Dell Inspiron 11-3162 LCD Screen Replacement
Was du brauchst
  1. Dell Inspiron 11-3162 LCD Screen Replacement, Back Cover Removal: Schritt 1, Bild 1 von 2 Dell Inspiron 11-3162 LCD Screen Replacement, Back Cover Removal: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use tweezers to pry and remove the center screw cover on the back cover.
  2. Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to unscrew the nine 6.8 mm screws securing the back cover.
  3. Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Use a spudger to pry around the base edges of the back cover to loosen it from the laptop.
    • Do not fully remove the cover, as it is still attached to the laptop with cables.
  4. Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 4, Bild 3 von 3
    • If you are only replacing the battery, you can skip this step. Be careful not to strain the still-connected cable as you work.
    • Unlock the wide ZIF connector securing the flex cable.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
    • Pull the ribbon cable outwards to disconnect the back cover from the motherboard.
  5. Dell Inspiron 11-3162 LCD Screen Replacement, Battery: Schritt 5, Bild 1 von 2 Dell Inspiron 11-3162 LCD Screen Replacement, Battery: Schritt 5, Bild 2 von 2
    • Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
  6. Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 6, Bild 3 von 3
    • Use your fingers (or a set of tweezers) to disconnect the battery cable from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Lift and remove the battery from its recess.
  7. Dell Inspiron 11-3162 LCD Screen Replacement, Wireless WLAN Card: Schritt 7, Bild 1 von 2 Dell Inspiron 11-3162 LCD Screen Replacement, Wireless WLAN Card: Schritt 7, Bild 2 von 2
    • Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
  8. Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 8, Bild 2 von 2
    • Using the tweezers, pull the white and black wires off of the WiFi Chip.
  9. Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 9, Bild 1 von 1
    • Pull out the WiFi Chip.
  10. Dell Inspiron 11-3162 LCD Screen Replacement, LCD Screen: Schritt 10, Bild 1 von 2 Dell Inspiron 11-3162 LCD Screen Replacement, LCD Screen: Schritt 10, Bild 2 von 2
    • Remove the two screws that hold down the LCD hinges.
  11. Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 11, Bild 1 von 1
    • Pull the hinges back and remove the screen.
  12. Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 12, Bild 1 von 2 Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 12, Bild 2 von 2
    • Remove the hinge covers with your spudger tool.
  13. Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 13, Bild 1 von 2 Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 13, Bild 2 von 2
    • Carefully remove the LCD Bezel with your regular black nylon spudger tool by bringing it all the way around the outer edges of your screen.
  14. Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 14, Bild 1 von 3 Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 14, Bild 2 von 3 Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 14, Bild 3 von 3
    • Remove the four screws with a PH00 sized bit.
    • Flip the screen over.
  15. Dell Inspiron 11-3162 LCD Screen Replacement: Schritt 15, Bild 1 von 1
    • Loosen the tape, and remove the LCD Cable.
    • Remove the screen.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
2Leitfaden Kommentare
Between steps 9 and 10, the motherboard is removed and no description photos are provided for this. I undid the cable on the right hinge and then removed the hinges and screen with the motherboard in place, but the pictures definitely show it removed. Otherwise a very easy to follow process.
Philip Blakemore - Antwort
I agree with Philip’s comment re: the missing step between 9 and 10. I successfully followed these very clear instructions to repair my daughter’s Chromebook. Thank you!
Katrina Dalrymple - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 17
Insgesamt: 1,714
