Einleitung
This will show you how to remove & replace your motherboard. This would be a last step in attempting to repair your computer if you've attempted the other guides.
Ersatzteile
Keine Ersatzteile angegeben.
Use tweezers to pry and remove the center screw cover on the back cover.
Use a Phillips screwdriver to unscrew the nine 6.8 mm screws securing the back cover.
Use a spudger to pry around the base edges of the back cover to loosen it from the laptop.
Unlock the wide ZIF connector securing the flex cable.
Pull the ribbon cable outwards to disconnect the back cover from the motherboard.
Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
Use your fingers (or a set of tweezers) to disconnect the battery cable from the motherboard by gently pulling it towards the battery.
Lift and remove the battery from its recess.
Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
Use the phillips screwdriver with the PH0 to loosen the 4 screws and remove the orange plate.
Use the phillips screwdriver with the PH00 head to unscrew the one 3mm screw. Then, remove the bracket.
5 weitere Nutzer haben diese Anleitung absolviert.
