Zum Hauptinhalt wechseln
Dell Inspiron 11-3162 Wireless WLAN Card Replacement
Was du brauchst
  1. Dell Inspiron 11-3162 Wireless WLAN Card Replacement, Back Cover Removal: Schritt 1, Bild 1 von 2 Dell Inspiron 11-3162 Wireless WLAN Card Replacement, Back Cover Removal: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use tweezers to pry and remove the center screw cover on the back cover.
  2. Dell Inspiron 11-3162 Wireless WLAN Card Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 11-3162 Wireless WLAN Card Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to unscrew the nine 6.8 mm screws securing the back cover.
  3. Dell Inspiron 11-3162 Wireless WLAN Card Replacement: Schritt 3, Bild 1 von 1
    • Use a spudger to pry around the base edges of the back cover to loosen it from the laptop.
    • Do not fully remove the cover, as it is still attached to the laptop with cables.
  4. Dell Inspiron 11-3162 Wireless WLAN Card Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 11-3162 Wireless WLAN Card Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 11-3162 Wireless WLAN Card Replacement: Schritt 4, Bild 3 von 3
    • If you are only replacing the battery, you can skip this step. Be careful not to strain the still-connected cable as you work.
    • Unlock the wide ZIF connector securing the flex cable.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap.
    • Pull the ribbon cable outwards to disconnect the back cover from the motherboard.
  5. Dell Inspiron 11-3162 Wireless WLAN Card Replacement, Battery: Schritt 5, Bild 1 von 2 Dell Inspiron 11-3162 Wireless WLAN Card Replacement, Battery: Schritt 5, Bild 2 von 2
    • Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
  6. Dell Inspiron 11-3162 Wireless WLAN Card Replacement: Schritt 6, Bild 1 von 3 Dell Inspiron 11-3162 Wireless WLAN Card Replacement: Schritt 6, Bild 2 von 3 Dell Inspiron 11-3162 Wireless WLAN Card Replacement: Schritt 6, Bild 3 von 3
    • Use your fingers (or a set of tweezers) to disconnect the battery cable from the motherboard by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Lift and remove the battery from its recess.
  7. Dell Inspiron 11-3162 Wireless WLAN Card Replacement, Wireless WLAN Card: Schritt 7, Bild 1 von 2 Dell Inspiron 11-3162 Wireless WLAN Card Replacement, Wireless WLAN Card: Schritt 7, Bild 2 von 2
    • Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
  8. Dell Inspiron 11-3162 Wireless WLAN Card Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron 11-3162 Wireless WLAN Card Replacement: Schritt 8, Bild 2 von 2
    • Using the tweezers, pull the white and black wires off of the WiFi Chip.
  9. Dell Inspiron 11-3162 Wireless WLAN Card Replacement: Schritt 9, Bild 1 von 1
    • Pull out the WiFi Chip.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 18
Insgesamt: 710
