Einleitung
If you clicked this link from the troubleshooting guide, follow these steps to help get your wireless back up and running.
Ersatzteile
Keine Ersatzteile angegeben.
Use tweezers to pry and remove the center screw cover on the back cover.
Use a Phillips screwdriver to unscrew the nine 6.8 mm screws securing the back cover.
Use a spudger to pry around the base edges of the back cover to loosen it from the laptop.
Unlock the wide ZIF connector securing the flex cable.
Pull the ribbon cable outwards to disconnect the back cover from the motherboard.
Use a Phillips screwdriver to unscrew the three 4 mm screws securing the battery.
Use your fingers (or a set of tweezers) to disconnect the battery cable from the motherboard by gently pulling it towards the battery.
Lift and remove the battery from its recess.
Use the phillips screwdriver with the PH000 head to unscrew the 3.8mm screw.
3 weitere Nutzer haben diese Anleitung absolviert.
