Zum Hauptinhalt wechseln
Dell Inspiron 13 7378 Heat Sink Replacement
Was du brauchst
  1. Dell Inspiron 13 7378 Heat Sink Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Set the laptop with its underside facing up for improved accessibility.
  2. Dell Inspiron 13 7378 Heat Sink Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 13 7378 Heat Sink Replacement: Schritt 2, Bild 2 von 2
    • Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
  3. Dell Inspiron 13 7378 Heat Sink Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 13 7378 Heat Sink Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 13 7378 Heat Sink Replacement: Schritt 3, Bild 3 von 3
    • Carefully pry open the back of the back of the laptop using opening picks.
    • Carefully raise and detach the back cover from the laptop.
    • Exercise caution to prevent damaging or cracking the device's back cover.
  4. Dell Inspiron 13 7378 Heat Sink Replacement, Heat Sink: Schritt 4, Bild 1 von 1
    • Carefully remove the four screws securing the heat sink by using a Phillips screwdriver.
  5. Dell Inspiron 13 7378 Heat Sink Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 13 7378 Heat Sink Replacement: Schritt 5, Bild 2 von 2
    • Check to see if the fan will obstruct the removal process and if so, remove the fan first before removing the heat sink to prevent any damage.
    • In the absence of any obstacles impeding the removal process, gently lift and extract the heat sink from its position.
  6. Dell Inspiron 13 7378 Heat Sink Replacement: Schritt 6, Bild 1 von 1
    • Before you install a new compatible cooling system, place a fresh coat of thermal paste in the center of where the previous cooling system used to be.
Abschluss
Replace the back cover to complete the process.
3 weitere Personen haben diese Anleitung absolviert.
Javier Perez
277 Reputation
2 Anleitungen geschrieben
Gateway, Team 1-3, Saknee Spring 2022 Mitglied von Gateway, Team 1-3, Saknee Spring 2022
GCC-SAKNEE-S22S1G3
5 Mitglieder
16 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 8
Insgesamt: 408
