Einleitung
The Dell Inspiron 13 7378 is a widely used laptop model, however, it is not immune to technical issues. One of the most prevalent problems faced by this device is CPU overheating. To mitigate this issue, it is crucial to replace the cooling system and prevent any harm to the internal components of the laptop. This guide will provide you with step-by-step instructions on how to perform this maintenance procedure in a professional manner.
Was du brauchst
Set the laptop with its underside facing up for improved accessibility.
Using a Phillips #00 screwdriver, extract the nine 3 mm screws located on the back of the laptop.
Carefully pry open the back of the back of the laptop using opening picks.
Carefully raise and detach the back cover from the laptop.
Carefully remove the four screws securing the heat sink by using a Phillips screwdriver.
In the absence of any obstacles impeding the removal process, gently lift and extract the heat sink from its position.
Replace the back cover to complete the process.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
