Zum Hauptinhalt wechseln
Dell Inspiron 13-5368 Audio Jack Replacement
Was du brauchst
    1. Dell Inspiron 13-5368 Audio Jack Replacement, 3.5 mm Audio Jack: Schritt 1, Bild 1 von 1
      • Use a Phillips #0 screwdriver to remove the 9 6mm screws securing the back plate of the laptop.
      Frag FixBot
      Kommentar hinzufügen
    2. Dell Inspiron 13-5368 Audio Jack Replacement: Schritt 2, Bild 1 von 1
      • Use a prying tool to remove the back plate.
      Frag FixBot
    3. Dell Inspiron 13-5368 Audio Jack Replacement: Schritt 3, Bild 1 von 1
      • Use a Phillips #0 screwdriver to remove the three 3 mm screws holding the battery in place.
      Frag FixBot
    4. Dell Inspiron 13-5368 Audio Jack Replacement: Schritt 4, Bild 1 von 1
      • Disconnect the cable connecting the battery to the motherboard, and then remove the battery.
      Frag FixBot
    5. Dell Inspiron 13-5368 Audio Jack Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron 13-5368 Audio Jack Replacement: Schritt 5, Bild 2 von 2
      • Using the Phillips #0 screwdriver, unscrew the 4 heatsink screws.
      • Remove the heatsink assembly.
      Frag FixBot
    6. Dell Inspiron 13-5368 Audio Jack Replacement: Schritt 6, Bild 1 von 1
      • Using the Phillips #0, unscrew two 3mm screws holding the fan in place and disconnect the cable connecting it to the motherboard. There is an adhesive tab holding the hard drive cable in place up against the fan; remove this as well.
      Frag FixBot
    7. Dell Inspiron 13-5368 Audio Jack Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron 13-5368 Audio Jack Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron 13-5368 Audio Jack Replacement: Schritt 7, Bild 3 von 3
      • Disconnect the following cables that connect to the motherboard: the Touchscreen, Display, and the speaker cable.
      Frag FixBot
    8. Dell Inspiron 13-5368 Audio Jack Replacement: Schritt 8, Bild 1 von 3 Dell Inspiron 13-5368 Audio Jack Replacement: Schritt 8, Bild 2 von 3 Dell Inspiron 13-5368 Audio Jack Replacement: Schritt 8, Bild 3 von 3
      • Disconnect the following cables that connect to the motherboard: hard drive cable and touchpad cable.
      Frag FixBot
    9. Dell Inspiron 13-5368 Audio Jack Replacement: Schritt 9, Bild 1 von 1
      • Using the Phillips #0 screwdriver, remove the three 2mm screws holding the motherboard in place. Once done, carefully lift the motherboard out.
      Frag FixBot
    10. Dell Inspiron 13-5368 Audio Jack Replacement: Schritt 10, Bild 1 von 1
      • Flip the motherboard over and, using a soldering iron, apply heat to the 7 solder points of the audio jack. Carefully pull the audio jack out from below.
      • For more tips on soldering, please visit the How to Solder and Desolder Connections guide.
      Frag FixBot
Abschluss
IUPUI, Team S4-G4, Wilson Fall 2018 Mitglied von IUPUI, Team S4-G4, Wilson Fall 2018
IUPUI-WILSON-F18S4G4
4 Mitglieder
24 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 45
Insgesamt: 2,799
