Zum Hauptinhalt wechseln
Dell Inspiron 13-7352 System Board Replacement
Was du brauchst
  1. Dell Inspiron 13-7352 System Board Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 13-7352 System Board Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 13-7352 System Board Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
  2. Dell Inspiron 13-7352 System Board Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 13-7352 System Board Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
  3. Dell Inspiron 13-7352 System Board Replacement: Schritt 3, Bild 1 von 1
    • Gently remove the battery from the rest of the device.
  4. Dell Inspiron 13-7352 System Board Replacement, Memory Module (RAM): Schritt 4, Bild 1 von 3 Dell Inspiron 13-7352 System Board Replacement, Memory Module (RAM): Schritt 4, Bild 2 von 3 Dell Inspiron 13-7352 System Board Replacement, Memory Module (RAM): Schritt 4, Bild 3 von 3
    • Locate your memory module (RAM).
    • Release the clips from the Memory Module by gently pushing down. This should cause the Memory Module to pop up and separate from the device base.
  5. Dell Inspiron 13-7352 System Board Replacement: Schritt 5, Bild 1 von 1
    • Pull the Memory Module from its slot by grasping each side with thumb and middle or index finger to pull from the rest of the device.
  6. Dell Inspiron 13-7352 System Board Replacement, System Board: Schritt 6, Bild 1 von 3 Dell Inspiron 13-7352 System Board Replacement, System Board: Schritt 6, Bild 2 von 3 Dell Inspiron 13-7352 System Board Replacement, System Board: Schritt 6, Bild 3 von 3
    • Remove cord that runs from system board to the I/O board.
    • Remove connecting wire that runs from fan to system board.
  7. Dell Inspiron 13-7352 System Board Replacement: Schritt 7, Bild 1 von 1
    • Remove the 3mm and 4mm screws using the Phillips #0 head for both that hold down the fan
  8. Dell Inspiron 13-7352 System Board Replacement: Schritt 8, Bild 1 von 1
    • Lift the fan from the system board by using your thumb and index or middle finger to gently pull away from the rest of the device.
  9. Dell Inspiron 13-7352 System Board Replacement: Schritt 9, Bild 1 von 3 Dell Inspiron 13-7352 System Board Replacement: Schritt 9, Bild 2 von 3 Dell Inspiron 13-7352 System Board Replacement: Schritt 9, Bild 3 von 3
    • Remove the three 4mm screws with the Phillips #0 holding down the heat sink.
    • Remove the two 4mm screws with the Phillips #0 holding down the metal bracket.
    • Unscrew the single 3mm screw using the Phillips #0 head securing the system board.
  10. Dell Inspiron 13-7352 System Board Replacement: Schritt 10, Bild 1 von 2 Dell Inspiron 13-7352 System Board Replacement: Schritt 10, Bild 2 von 2
    • Remove the wire connections attached to the system board.
    • Remove the tape wires from the system board.
  11. Dell Inspiron 13-7352 System Board Replacement: Schritt 11, Bild 1 von 1
    • Carefully remove the system board from the base by grasping with thumb and index or middle finger and pulling away from the rest of the device.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Chris Monte
411 Reputation
2 Anleitungen geschrieben
University of Tampa, Team 1-5, Whiteside Fall 2015 Mitglied von University of Tampa, Team 1-5, Whiteside Fall 2015
UT-WHITESIDE-F15S1G5
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 1,907
