Zum Hauptinhalt wechseln
Dell Inspiron 13-7352 Memory Module (RAM) Replacement
Was du brauchst
  1. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: Schritt 1, Bild 1 von 3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: Schritt 1, Bild 2 von 3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Battery: Schritt 1, Bild 3 von 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Phillips screwdriver to remove the ten 7.5mm screws that securing the back panel.
    • Use the plastic opening tool to pry up and loosen the back panel.
    • Remove the back panel.
    Frag FixBot
    Kommentar hinzufügen
  2. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 13-7352 Memory Module (RAM) Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips screwdriver to remove the two 3 mm screws securing the battery.
    • Unclip the hard drive wire from the battery.
    Frag FixBot
  3. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: Schritt 3, Bild 1 von 1
    • Gently remove the battery from the rest of the device.
    Frag FixBot
  4. Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): Schritt 4, Bild 1 von 3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): Schritt 4, Bild 2 von 3 Dell Inspiron 13-7352 Memory Module (RAM) Replacement, Memory Module (RAM): Schritt 4, Bild 3 von 3
    • Locate your memory module (RAM).
    • Release the clips from the Memory Module by gently pushing down. This should cause the Memory Module to pop up and separate from the device base.
    Frag FixBot
  5. Dell Inspiron 13-7352 Memory Module (RAM) Replacement: Schritt 5, Bild 1 von 1
    • Pull the Memory Module from its slot by grasping each side with thumb and middle or index finger to pull from the rest of the device.
    Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
University of Tampa, Team 1-5, Whiteside Fall 2015 Mitglied von University of Tampa, Team 1-5, Whiteside Fall 2015
UT-WHITESIDE-F15S1G5
3 Mitglieder
6 Anleitungen geschrieben
4 Kommentare zur Anleitung
Hello is the procedure same for 7353 ? can the ram be upgraded to 16GB. it currently has 8GB
Ali M - Antwort Teilen
Hi! Same questions as Ali M: Is the procedure same for 7353 ? can the ram be upgraded to 16GB: It currently has 8GB and I'd like to upgrade it to 16 GB.
Roberto de Souza Santos - Antwort Teilen
Did anyone ever get an answer if it can take 16 GB of RAM?
Robert Iversen - Antwort Teilen
A 16GB RAM would work but it should be a single sodimm module like CT204864BF160B
Hochan Son - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 8
Letzte 30 Tage: 40
Insgesamt: 3,663
