Zum Hauptinhalt wechseln
Dell Inspiron 13-7373 Daughterboard Replacement
Was du brauchst
  1. Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: Schritt 1, Bild 1 von 3 Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: Schritt 1, Bild 2 von 3 Dell Inspiron 13-7373 Daughterboard Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Remove the ten 7.5mm Phillips #00 screws from the bottom of the laptop.
    • Use an opening tool to remove the bottom half of the case from the laptop.
  2. Dell Inspiron 13-7373 Daughterboard Replacement, Network Card: Schritt 2, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the single screw holding in the network card.
    • Remove the network card from the laptop.
  3. Dell Inspiron 13-7373 Daughterboard Replacement, Daughterboard: Schritt 3, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the two 1mm screws holding in the daughterboard.
    • Remove the metal piece holding in the daughterboard.
    • Disconnect the two cable connectors from the daughterboard.
    • If the cables are stuck, gently wiggle them until they disconnect.
  4. Dell Inspiron 13-7373 Daughterboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the daughterboard.
Abschluss
Kristen Gismondi
91.979 Reputation
241 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
118 Mitglieder
19.449 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 15
Insgesamt: 345
