Zum Hauptinhalt wechseln
Dell Inspiron 14-5415 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 14-5415 Hard Drive Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Close the lid and turn the laptop over to access the back cover.
  2. Dell Inspiron 14-5415 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Remove the five 4 mm screws from the back of the laptop using a Phillips #0 screwdriver.
    • Loosen the two remaining captive screws using a Phillips #0 screwdriver.
    • Captive screws tend to have a slightly larger head than normal screws, so it is important to use the correct size screwdriver to avoid damaging the screw or the device.
  3. Dell Inspiron 14-5415 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 2 Dell Inspiron 14-5415 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 2 von 2
    • Remove the screw from the hard drive using a Phillips #00 screwdriver.
  4. Dell Inspiron 14-5415 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Carefully pull the hard drive out of its position.
    • Be sure to handle the hard drive with care. It should not need to be pulled hard to remove.
Abschluss
Ilana Ek-Adler
85 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 25
Insgesamt: 232
