Zum Hauptinhalt wechseln
Dell Inspiron 14-7437 Thermal Cooling Fan Replacement
Was du brauchst
  1. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Base Cover: Schritt 1, Bild 1 von 2 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Base Cover: Schritt 1, Bild 2 von 2
    • Power off your Dell Inspiron 14-7437 before disassembling.
    • Remove the eight 4.5 mm screws on the back panel of the device using the Phillips 1 Screwdriver.
    • The two 4.5 mm screws in the center under the rubber mount cannot be removed, but can be loosened.
  2. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: Schritt 2, Bild 2 von 2
    • Pry open the back cover using a spudger and slide it along the under the cover.
  3. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Battery: Schritt 3, Bild 1 von 2 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Battery: Schritt 3, Bild 2 von 2
    • Remove the two 2.5 mm screws holding the battery in place using the J000 Phillips Head Screwdriver.
  4. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the ribbon cables from the motherboard.
  5. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: Schritt 5, Bild 1 von 1
    • Lift up and remove the Lithium-Polymer Battery.
  6. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Speaker: Schritt 6, Bild 1 von 1
    • Disconnect wires from Motherboard by gently pulling up.
  7. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: Schritt 7, Bild 3 von 3
    • Remove the speakers from the case.
  8. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Coin Cell Battery: Schritt 8, Bild 1 von 1
    • Lift the coin cell battery wire, and carefully remove from motherboard.
    • There are little hooks that the wire is hooked under.
  9. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: Schritt 9, Bild 1 von 2 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: Schritt 9, Bild 2 von 2
    • Remove the Coin-Cell Battery from the case.
    • There is a small amount of adhesive on the bottom of the coin cell battery.
  10. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Cooling Fan: Schritt 10, Bild 1 von 2 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Cooling Fan: Schritt 10, Bild 2 von 2
    • Remove the two 2.5 mm screws using a J000 Phillips Head Screwdriver.
  11. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: Schritt 11, Bild 1 von 2 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: Schritt 11, Bild 2 von 2
    • Pull up on the wire and remove the Cooling Fan.
  12. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Thermal-Cooling Assembly: Schritt 12, Bild 1 von 3 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Thermal-Cooling Assembly: Schritt 12, Bild 2 von 3 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement, Thermal-Cooling Assembly: Schritt 12, Bild 3 von 3
    • Disconnect cables connected to the motherboard by lifting the flaps up and pulling out.
    • This is a ZIF connector and needs to have the side flaps flipped up before removal.
    • The ZIF connector has small clips that need to be pulled up before being pulled out.
  13. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: Schritt 13, Bild 1 von 3 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: Schritt 13, Bild 2 von 3 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: Schritt 13, Bild 3 von 3
    • Remove the eight 2.5 mm screws using a J000 Phillips Head Screwdriver.
  14. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: Schritt 14, Bild 1 von 2 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: Schritt 14, Bild 2 von 2
    • Flip the motherboard.
  15. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: Schritt 15, Bild 1 von 2 Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: Schritt 15, Bild 2 von 2
    • Loosen the three 2.5 mm screws using the J000 Phillips Head Screwdriver.
    • These three 2.5 mm screws cannot be removed from the Thermal Cooling assembly.
  16. Dell Inspiron 14-7437 Thermal Cooling Fan Replacement: Schritt 16, Bild 1 von 1
    • Remove the Thermal-Cooling Assembly from the motherboard.
Abschluss
Katelyn Remy
449 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 7-8, Catania Spring 2016 Mitglied von UMass Dartmouth, Team 7-8, Catania Spring 2016
UMASSD-CATANIA-S16S7G8
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 14
Insgesamt: 1,120
