Zum Hauptinhalt wechseln
Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement
Was du brauchst
  1. Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement, Battery removal: Schritt 1, Bild 1 von 1
    • Turn the laptop over and unlock the battery by sliding the two locking tabs away from each other. The one on the left is spring loaded. Slide the battery out.
    • Simply slide the battery out in the direction shown.
  2. Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement, RAM removal: Schritt 2, Bild 1 von 2 Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement, RAM removal: Schritt 2, Bild 2 von 2
    • Undo the locking screw on RAM cover, then prise open the cover.
    • Release the RAM module or modules by pushing the metal clips outwards. Put the modules aside.
    • On reinserting the RAM modules, ensure that they are fully home in their sockets before angling them downwards to engage the clips.
  3. Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement, Bottom screws: Schritt 3, Bild 1 von 2 Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement, Bottom screws: Schritt 3, Bild 2 von 2
    • Note: if the laptop you are working on is a very slightly different model it is possible that it will have a different number of screws in slightly different positions. The important thing is to note where the shorter screws come from so as to avoid inserting a longer screw in its place on reassembly.
    • Remove a 5mm screw to the left of the RAM sockets, then pull out the CD/DVD drive. (Not necessary if you are only replacing the keyboard.)
    • Remove a 5mm screw to the right and the rear of the RAM sockets.
    • If you are going to remove the hard disk, motherboard or fan, remove 4 3mm screws.
    • Remove 7 5mm screws. (There are 6 more at the rear which should be left.)
  4. Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 15 (N5010) RAM, CD/DVD drive or Keyboard Replacement: Schritt 4, Bild 2 von 2
    • With a thin metal spudger you should now be able to release 4 clips along the top of the keyboard in order to lift it out.
    • If you find one or more of the tabs refuse to release, do not force it. You probably missed one (or more) of the screws in the bottom.
    • Lift the keyboard slightly from the back, disengaging its tabs along the front panel at the front. Turn it over towards you, taking care not to strain the ribbon.
    • Gently lift the locking bar on the ribbon socket and withdraw the ribbon. Put the keyboard aside.
Abschluss
Philip Le Riche
30.183 Reputation
47 Anleitungen geschrieben
Restart Project Mitglied von Restart Project
Local Repair Groups
19 Mitglieder
557 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 22
Insgesamt: 774
