Einleitung
Use this guide to assist in removing the bottom cover on your Dell Inspiron 15 5584 laptop.
The bottom cover serves as a guard to protect the sensitive hardware components within the machine and acts as a surface to place the laptop as well. All hardware issues within the Dell Inspiron 15 5584 require you to remove the bottom cover to resolve them.
Before using this guide, make sure to review the troubleshooting page and confirm what issue you are having with your device. Keeping the bottom cover off for too long may result in components becoming damaged. Furthermore, when removing the bottom cover, clicking and snapping sounds are normal; however, the bottom cover is made of hard plastic that can easily snap.
Was du brauchst
Turn over the laptop so that the bottom is facing upwards, and the Inspiron logo is upside-down.
Remove the seven 7 mm screws from the bottom using a Phillips #0 screwdriver.
Loosen the two captive back corner screws using a Phillips #0 screwdriver.
Slide an iFixit opening tool underneath the right side USB port and the keyboard.
Gently trace the iFixit opening tool along the entire outer rim of the laptop, carefully applying an upwards pressure.
Gently pry off the bottom cover from the laptop.
Use the iFixit opening tool to loosen any spots you may have missed from Step 3.
