Zum Hauptinhalt wechseln
Dell Inspiron 15-5565 Wireless Card Replacement
Was du brauchst
  1. Dell Inspiron 15-5565 Wireless Card Replacement, Optical Drive: Schritt 1, Bild 1 von 1
    • Remove the 4 mm screw that secures the optical drive bracket to the optical drive using a Phillips #00 screwdriver.
  2. Dell Inspiron 15-5565 Wireless Card Replacement: Schritt 2, Bild 1 von 3 Dell Inspiron 15-5565 Wireless Card Replacement: Schritt 2, Bild 2 von 3 Dell Inspiron 15-5565 Wireless Card Replacement: Schritt 2, Bild 3 von 3
    • Eject the optical drive by pressing the eject button.
    • Push out the optical drive bracket using the iFixit opening tool.
  3. Dell Inspiron 15-5565 Wireless Card Replacement, Back Cover: Schritt 3, Bild 1 von 2 Dell Inspiron 15-5565 Wireless Card Replacement, Back Cover: Schritt 3, Bild 2 von 2
    • Remove 13 8 mm screws from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the single 4 mm screw from the bottom of the device using a Phillips #00 screwdriver.
    • Remove the three 4 mm screws from the optical drive slot using a Phillips #00 screwdriver.
  4. Dell Inspiron 15-5565 Wireless Card Replacement: Schritt 4, Bild 1 von 2 Dell Inspiron 15-5565 Wireless Card Replacement: Schritt 4, Bild 2 von 2
    • Remove the back cover from the laptop.
  5. Dell Inspiron 15-5565 Wireless Card Replacement, Wireless Card: Schritt 5, Bild 1 von 2 Dell Inspiron 15-5565 Wireless Card Replacement, Wireless Card: Schritt 5, Bild 2 von 2
    • Remove the single screw securing the wireless card bracket using a Phillips #00 screwdriver.
    • Slide the bracket to remove it.
    • Disconnect the two cables from the wireless card.
  6. Dell Inspiron 15-5565 Wireless Card Replacement: Schritt 6, Bild 1 von 1
    • Slide out the wireless card to remove it from its slot.
Abschluss
Shayne Cola
181 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 119
