Zum Hauptinhalt wechseln
Dell Inspiron 7000 2 in 1 Battery Replacement
Was du brauchst
  1. Dell Inspiron 7000 2 in 1 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip your Dell Inspiron 7000 2 in 1 laptop upside down to get started. Find the locations of all the 10 screws.
    • Remember to turn the laptop off before you begin the repair.
  2. Dell Inspiron 7000 2 in 1 Battery Replacement: Schritt 2, Bild 1 von 1
    • Using your Phillips #00 screwdriver, remove the ten 7.00 mm screws at the bottom of the laptop.
  3. Dell Inspiron 7000 2 in 1 Battery Replacement: Schritt 3, Bild 1 von 3 Dell Inspiron 7000 2 in 1 Battery Replacement: Schritt 3, Bild 2 von 3 Dell Inspiron 7000 2 in 1 Battery Replacement: Schritt 3, Bild 3 von 3
    • Insert the spudger in the gap between the bottom cover and the frame. Then, use it as a wedge and work your way around the perimeter. This will pop open the bottom cover of the laptop.
  4. Dell Inspiron 7000 2 in 1 Battery Replacement: Schritt 4, Bild 1 von 1
    • Find the battery located at the bottom right corner of the laptop.
  5. Dell Inspiron 7000 2 in 1 Battery Replacement: Schritt 5, Bild 1 von 1
    • Now remove the four 4.0 mm Phillips #00 screws located at each corner of the battery.
  6. Dell Inspiron 7000 2 in 1 Battery Replacement: Schritt 6, Bild 1 von 1
    • Remove the battery pin that is connecting the motherboard to the battery by pulling out the pin gently.
    • Remember to safely recycle your old laptop battery.
  7. Dell Inspiron 7000 2 in 1 Battery Replacement: Schritt 7, Bild 1 von 1
    • Reinsert the battery pin into the new battery and place it back into its position.
  8. Dell Inspiron 7000 2 in 1 Battery Replacement: Schritt 8, Bild 1 von 1
    • Screw the four 4.0 mm Phillips #00 head screws for the battery back into place to make sure the battery is held on securely.
  9. Dell Inspiron 7000 2 in 1 Battery Replacement: Schritt 9, Bild 1 von 1
    • Place the cover back onto the laptop and press down on all corners and sides.
    • Make sure to listen for a click to ensure the cover is properly secured.
  10. Dell Inspiron 7000 2 in 1 Battery Replacement: Schritt 10, Bild 1 von 1
    • Use the Phillips #00 screwdriver to replace the ten 7.00 mm screws on the back cover.
Ziellinie
3 weitere Personen haben diese Anleitung absolviert.
York University, Team E-31, Melo-Thaiss Fall 2021 Mitglied von York University, Team E-31, Melo-Thaiss Fall 2021
YORK-MELO-THAISS-F21SEG31
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 25
Letzte 30 Tage: 90
Insgesamt: 7,151
