Zum Hauptinhalt wechseln
Dell Latitude D430 Hard Drive Replacement
Was du brauchst
  1. Dell Latitude D430 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Latitude D430 Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the laptop over and make the bottom of the laptop face up.
  2. Dell Latitude D430 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Place your fingers on the black latches indicated in the picture.
  3. Dell Latitude D430 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Side them until you hear a click.
  4. Dell Latitude D430 Hard Drive Replacement: Schritt 4, Bild 1 von 2 Dell Latitude D430 Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Place both hands over the edge of the battery and pull up.
  5. Dell Latitude D430 Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 3 Dell Latitude D430 Hard Drive Replacement, Hard Drive: Schritt 5, Bild 2 von 3 Dell Latitude D430 Hard Drive Replacement, Hard Drive: Schritt 5, Bild 3 von 3
    • Remove the screws keeping the hard drive in place using a PH00 Philips screwdriver.
  6. Dell Latitude D430 Hard Drive Replacement: Schritt 6, Bild 1 von 3 Dell Latitude D430 Hard Drive Replacement: Schritt 6, Bild 2 von 3 Dell Latitude D430 Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Remove the silver plate by pushing it towards the back of the laptop.
    • You may need to use significant force.
    • Remove the plate.
  7. Dell Latitude D430 Hard Drive Replacement: Schritt 7, Bild 1 von 3 Dell Latitude D430 Hard Drive Replacement: Schritt 7, Bild 2 von 3 Dell Latitude D430 Hard Drive Replacement: Schritt 7, Bild 3 von 3
    • Flip the hard drive upside down.
    • Pull the switch locking the tape cord in place up.
    • Pull on the tape to remove it.
  8. Dell Latitude D430 Hard Drive Replacement: Schritt 8, Bild 1 von 2 Dell Latitude D430 Hard Drive Replacement: Schritt 8, Bild 2 von 2
    • Remove the Hard Drive.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 39
Insgesamt: 3,820
