Zum Hauptinhalt wechseln
Dell Latitude E7440 WLAN Card Replacement
Was du brauchst
  1. Dell Latitude E7440 WLAN Card Replacement, Prepare the laptop: Schritt 1, Bild 1 von 1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 WLAN Card Replacement, Release the battery: Schritt 2, Bild 1 von 3 Dell Latitude E7440 WLAN Card Replacement, Release the battery: Schritt 2, Bild 2 von 3 Dell Latitude E7440 WLAN Card Replacement, Release the battery: Schritt 2, Bild 3 von 3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 WLAN Card Replacement, Remove the battery: Schritt 3, Bild 1 von 1
    • Lift the battery by the top, away from the laptop body.
  4. Dell Latitude E7440 WLAN Card Replacement, WLAN Card: Schritt 4, Bild 1 von 2 Dell Latitude E7440 WLAN Card Replacement, WLAN Card: Schritt 4, Bild 2 von 2
    • Remove two M2 x 3mm Phillips #0 screws from the base cover.
  5. Dell Latitude E7440 WLAN Card Replacement: Schritt 5, Bild 1 von 3 Dell Latitude E7440 WLAN Card Replacement: Schritt 5, Bild 2 von 3 Dell Latitude E7440 WLAN Card Replacement: Schritt 5, Bild 3 von 3
    • Slide the base cover down slightly and remove it to find the WLAN card.
  6. Dell Latitude E7440 WLAN Card Replacement: Schritt 6, Bild 1 von 3 Dell Latitude E7440 WLAN Card Replacement: Schritt 6, Bild 2 von 3 Dell Latitude E7440 WLAN Card Replacement: Schritt 6, Bild 3 von 3
    • Disconnect the white and black wires attached to the WLAN card by pulling them away from the card.
    • You can use the nylon spudger to disconnect a wire by placing it between the curved part of the wire and gently pulling.
    • When attaching the wires to the WLAN card, place the wire head directly above the connectors and apply pressure to the head to reconnect it.
  7. Dell Latitude E7440 WLAN Card Replacement: Schritt 7, Bild 1 von 3 Dell Latitude E7440 WLAN Card Replacement: Schritt 7, Bild 2 von 3 Dell Latitude E7440 WLAN Card Replacement: Schritt 7, Bild 3 von 3
    • Remove a M2 x 3mm Phillips #0 screw from the WLAN card.
    • Gently pull the WLAN card out of its socket.
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
Akash Kedia
1.445 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S2-G5, White Winter 2019 Mitglied von Cal Poly, Team S2-G5, White Winter 2019
CPSU-WHITE-W19S2G5
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 14
Letzte 30 Tage: 34
Insgesamt: 4,347
