Einleitung
This guide will show you how to replace the motherboard of the Dell Vostro 5510. The motherboard is the part of a computer which connects all of its internal components and transmits both information and power. A typical symptom of a faulty motherboard is a totally dead system; however, it is common for a power supply issue to be confused with a motherboard issue. If the system remains dead after replacing the power supply, there is most likely a problem with the motherboard. See this link for more information on motherboard troubleshooting: Computer Motherboard Troubleshooting.
Was du brauchst
Remove the remaining (M2x4mm) screws with the screwdriver.
Loosen the two captive (M2x7.5mm) corner screws with the screwdriver.
Pry open the top left corner of the cover with the opening tool.
Pry open the top right corner of the cover with the opening tool.
Pry the rest of the cover with the opening tool, working in a clockwise motion until it is completely loosened.
Remove the screw (M2x3mm) from the wireless card with the screwdriver.
Lift the card without removing it completely.
Loosen the four 2.9 mm screws from the heat pipe with the Phillips #0 screwdriver.
Remove the heat pipe with your fingers.
Remove the three 4.9 mm screws from the hinge on the left with the Phillips #0 screwdriver.
Lift the hinge up from the motherboard.
Remove the two 4.7 mm screws from the metal plate on the left of the motherboard with the Phillips #0 screwdriver.
Remove the metal plate with your fingers.
Remove the 3.7 mm screw from the flat plate at the top of the motherboard with the Phillips #0 screwdriver.
Remove the flat plate with your fingers.
Remove the three 2.2 mm screws from the motherboard with a Phillips #0 screwdriver.
Disconnect the white plug from the bottom of the motherboard.
Remove the entire part the plug is attached to with your fingers.
Disconnect the thick cord from the right of the motherboard with your fingers.
