Zum Hauptinhalt wechseln
Dell XPS 14 RAM Replacement
Was du brauchst
  1. Dell XPS 14 RAM Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Position the computer back side up so that the “XPS” logo is facing you.
    • Remove six 3 mm screws along the perimeter of the back panel using a T5 Torx screwdriver.
  2. Dell XPS 14 RAM Replacement: Schritt 2, Bild 1 von 3 Dell XPS 14 RAM Replacement: Schritt 2, Bild 2 von 3 Dell XPS 14 RAM Replacement: Schritt 2, Bild 3 von 3
    • Use an opening tool to pry up the metal plate.
    • Remove the two 6 mm screws under the silver flap using a Phillips #0 screwdriver.
  3. Dell XPS 14 RAM Replacement: Schritt 3, Bild 1 von 2 Dell XPS 14 RAM Replacement: Schritt 3, Bild 2 von 2
    • Use an opening tool to pop out the back panel.
    • Once unhinged, the panel will open away from you.
    • The back panel will still be attached by a ribbon cable. Be cautious when opening the panel to ensure the ribbon stays intact.
  4. Dell XPS 14 RAM Replacement: Schritt 4, Bild 1 von 3 Dell XPS 14 RAM Replacement: Schritt 4, Bild 2 von 3 Dell XPS 14 RAM Replacement: Schritt 4, Bild 3 von 3
    • Flip over the back panel so that the interior of the panel is facing up.
    • Remove three 2 mm screws that are connected to the vendor GCE disk on the bottom left corner of the back panel using a Phillips #0 screwdriver.
    • Remove the black plastic cover that holds the disk in place.
    • Remove the back panel.
    • The GCE disk should still be connected to the computer via a purple ribbon cable.
  5. Dell XPS 14 RAM Replacement, Speaker: Schritt 5, Bild 1 von 2 Dell XPS 14 RAM Replacement, Speaker: Schritt 5, Bild 2 von 2
    • Remove four 2 mm screws that are connected to the speaker using a Phillips #0 screwdriver.
  6. Dell XPS 14 RAM Replacement: Schritt 6, Bild 1 von 2 Dell XPS 14 RAM Replacement: Schritt 6, Bild 2 von 2
    • Remove the speaker from its original location so the wire connector is visible.
    • Unplug the red and white cable plug by pulling out the white end tag.
    • The speaker is now fully removed.
  7. Dell XPS 14 RAM Replacement, Battery: Schritt 7, Bild 1 von 1
    • Make sure to ground yourself before removing the battery.
    • Remove the four 6 mm screws from the sides of the battery using a T5 Torx screwdriver.
    • Remove the two 3 mm screws from the top of the battery using a Phillips #0 screwdriver.
  8. Dell XPS 14 RAM Replacement: Schritt 8, Bild 1 von 3 Dell XPS 14 RAM Replacement: Schritt 8, Bild 2 von 3 Dell XPS 14 RAM Replacement: Schritt 8, Bild 3 von 3
    • Detach the battery connector from the motherboard using two thumbs to pop it out.
    • Remove the battery from the laptop.
  9. Dell XPS 14 RAM Replacement, RAM: Schritt 9, Bild 1 von 3 Dell XPS 14 RAM Replacement, RAM: Schritt 9, Bild 2 von 3 Dell XPS 14 RAM Replacement, RAM: Schritt 9, Bild 3 von 3
    • Remove any electrical tape that may be covering or overlapping the RAM cartridge.
    • Push the two metal latches on either side of the RAM outward.
    • The cartridge will pop out of the laptop.
  10. Dell XPS 14 RAM Replacement: Schritt 10, Bild 1 von 2 Dell XPS 14 RAM Replacement: Schritt 10, Bild 2 von 2
    • Slide the RAM cartridge out of its slot.
Abschluss
UMass Dartmouth, Team 1-3, Botvin Spring 2022 Mitglied von UMass Dartmouth, Team 1-3, Botvin Spring 2022
UMASSD-BOTVIN-S22S1G3
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 25
Insgesamt: 260
