Einleitung
Replacing the battery of a Dell XPS 15 9510 laptop is a straightforward task requiring only a few tools. The new battery constitutes nearly all of the cost of this repair, so if you are planning to order a replacement battery for this or any other laptop, it may be wise to remove the back panel of the laptop to ensure that the one you are ordering matches the existing one.
If the battery you are replacing is swollen, be sure to take appropriate precautions.
Was du brauchst
Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
Wedge the case apart with a nylon spudger.
Slide spudger along each side of the laptop
Using the small battery pull tab, disconnect the battery connector from the motherboard.
Remove eight 2.5 mm from around the perimeter of the battery using a Phillips #0 screwdriver.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
