Zum Hauptinhalt wechseln
Dell XPS 15 9510 RAM Replacement
Was du brauchst
  1. Dell XPS 15 9510 RAM Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 RAM Replacement: Schritt 2, Bild 1 von 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 RAM Replacement: Schritt 3, Bild 1 von 1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 RAM Replacement, RAM: Schritt 4, Bild 1 von 1
    • Using both hands, pull the clips that hold the RAM in place.
  5. Dell XPS 15 9510 RAM Replacement: Schritt 5, Bild 1 von 2 Dell XPS 15 9510 RAM Replacement: Schritt 5, Bild 2 von 2
    • Gently, with both hands, pull the RAM up at a 45º angle and take out the RAM.
    • Repeat the same process with the other RAM.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
IUPUI, Team 2-1, Harley Summer 2023 Mitglied von IUPUI, Team 2-1, Harley Summer 2023
IUPUI-HARLEY-SU23S2G1
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 14
Letzte 30 Tage: 45
Insgesamt: 1,744
