Zum Hauptinhalt wechseln
Dell XPS 15 9570 Heat Sink Replacement
Was du brauchst
  1. Dell XPS 15 9570 Heat Sink Replacement, Base Cover: Schritt 1, Bild 1 von 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Heat Sink Replacement: Schritt 2, Bild 1 von 3 Dell XPS 15 9570 Heat Sink Replacement: Schritt 2, Bild 2 von 3 Dell XPS 15 9570 Heat Sink Replacement: Schritt 2, Bild 3 von 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Heat Sink Replacement: Schritt 3, Bild 1 von 2 Dell XPS 15 9570 Heat Sink Replacement: Schritt 3, Bild 2 von 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Heat Sink Replacement: Schritt 4, Bild 1 von 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Heat Sink Replacement, Battery: Schritt 5, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Heat Sink Replacement: Schritt 6, Bild 1 von 1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Heat Sink Replacement: Schritt 7, Bild 1 von 1
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Heat Sink Replacement, Heat Sink: Schritt 8, Bild 1 von 2 Dell XPS 15 9570 Heat Sink Replacement, Heat Sink: Schritt 8, Bild 2 von 2
    • Use the Phillips #00 to remove the three (without graphics card) or four (with graphics card) 3 mm screws that connect the heat sink to the system board.
  9. Dell XPS 15 9570 Heat Sink Replacement: Schritt 9, Bild 1 von 1
    • Lift the heat sink from the device. The thermal paste may have dried and make this handling more complicated, be careful.
Abschluss
University of Alabama, Team 2-4, Bedsole Fall 2021 Mitglied von University of Alabama, Team 2-4, Bedsole Fall 2021
UA-BEDSOLE-F21S2G4
3 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 16
Letzte 30 Tage: 65
Insgesamt: 2,324
