Einleitung
If your computer is running hot then the fan my be broken or dirty. This guide will help you locate and remove the fan so you can clean or replace it.
Was du brauchst
Unscrew the four Phillips #1 screws holding down the back panel. Then remove one 5.8mm Phillips #1 screw labeled "M" in the middle of the back panel.
Four 3.9mm Phillips #1 screws
One 5.8mm Phillips #1 screw
First, unscrew the six screws that are holding down the fan and heat sink with a Philips #1 screwdriver. Then use a Phillips #1 to remove the single screw near the bottom of the heat sink.
Six Silver Chrome 5.8mm Phillips #1 screws
Use your fingers or a spudger to remove the power pin connecting the fan to the laptop by pulling it straight up off the motherboard.
Flip over the heat sink to remove the four 3.2mm Phillips #000 screws connecting the heat sink to the fan.
Four 3.2mm Phillips #000
2 weitere Personen haben diese Anleitung absolviert.
